Wheel not up against hub
I bought this s2000 back in September. I've replaced the wheel studs, tie rod ends and wheel bearings in both front wheels. I noticed on the driver's side wheel there is a 4mm gap between the wheel and the hub, which causes the rotor to back off and loosen up. Does anyone know what this problem might be? It's a large enough gap to fit my key into and I cannot tighten the wheel up against the hub.
Originally Posted by krikke_s2000,Dec 9 2008, 04:26 AM
front and rear wheels changed maybe i believe
the front wheels go on the back but the rears not on the front
grtz kristof
grtz kristof
Surely a front/rear swop would be obvious.?
