wheel hop over bumps?
when going over bumps on the highway/local streets at a bit higher speeds, i noticed that the front wheels hop to the side and i have to kick the steering wheel back to straighten out the car.
as you can tell this seems pretty dangerous if the wrong situation occurs.
i'm currently running skunk2 springs on koni adjustable shocks on the stiffest setting.
how can i fix this? i haven't got an alignment since i installed the suspension, would that make a difference?
hopefully this is a common thing with the S and aftermarket suspension..
Thanks
-Nick.
Thanks
-Nick.
the concern is it isn't even just heavy ruts/dips.
i was reading that it may be the wheels toeing out as the wheels come off the road..
would stiffening up the front end help at all? (sway bar, x brace, shock tower bar, etc.)
i have stock suspension and i notice the same thing, feels like i got front wheel drive with massive torque steer sometimes the way the wheel rips side to side,......the roads here and horrible though,...some people drive with studded tires year round
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
Get the 4 wheel alignment looked at. Even if nothing has been touched/altered before, it's likely that going over bumps/potholes will knock the tracking out.
A decent garage will check it for free and adjust for a reasonable price.
05TurboS2k
01-24-2009 12:58 PM
