is this a wheel bearing sound?
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
listen carefully when i hit the stop sign near the end of video and right when i pull into my driveway.
i hear this noise when im coasting from 40 and down. It get louder and louder at lower speed. i think it there at higher speed but i can barely hear it.
http://tinypic.com/r/316t7gn/7
trust me. when the wheel bearing gives out it will give out. there was no warnign for me at all lol. it just made a loud as BOOOM and that was it. and to top it off, i couldn't go any faster than what you posted in your vid. if i did go faster, then it would get REAAL loud.
i'm no mechanic btw, but when did that problem occur? i've had several mishaps with my drive train parts so i may help you out to diagnose this issue.
edit: ok i just watched your vid over and over and that's definately not what i think it is, which you stated as a wheel bearing. that's actually different from what i experienced in the past. i went through a rear diff, wheel bearing, transmission bearing in/out, and drive shaft.
none of those parts sounded like your problem. i'm gonna go out on a limb on this one and say it's the braking system. since whenever you decelerate the problem persist.
![frown.gif](https://www.s2ki.com/forums/images/smilies/frown.gif)
here's a how broken wheel bearing sounds like. it's not an s2k but the sound is EXACTLY the same.
[media]http://www.youtube.com/watch?v=XASIINpqC_I [/media]
Originally Posted by starchland,Feb 11 2011, 03:49 AM
but I also hear a knock, maybe axle?
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
It can knock, squeak, growl, and sound like sandpaper on wood. It depends on how it fails. Usually a squeak while turning in one direction, such as yours, is a bad bearing.
You definitely have a bad wheel bearing. You can probably jack that corner up and wiggle the wheel in and out.
Also, while you have the wheel up, give it a spin and see if you can hear anything.
I have just discovered this exact same issue on mine as of about 2-3 days ago.
The sounds from the video are identical to what I've been experiencing.
From searching, I've come up with these things to check:
I'll be heading over to a family member's garage here in an hour or so to pull things apart and see if any of the above matches while I change the motor, tranny, and diff oil. From a visual inspection, it looks like everything is in place with the rear suspension and is completely symmetrical with the other side.
Others suggest a bad wheel bearing, which is what I think it is, but won't know for sure until I get the car up on jackstands. I'll be keeping an eye on this thread, and will update it if I manage to somehow fix it.
I'm not sure if a seal or bearing somehow got sand in it from all the terrible winter weather DFW got the last two weeks, but there's friction somewhere, and I plan to find out wth is going on.
-Alex
- Greased/adjusted hood latch
- Axle shaft small bearing shield on the end rusted/rubbing?
- Grease fr/rr sway bar bushings
- Tighten upper a-arm
- Make sure all spring spacers are removed
- Maybe grease door jams
- Tighten spare tire
-Alex
