Wheel bearing sound?
Have a strange sound. Sounds like a wheel bearing but it's only when under load. On decel no sound. Around curves at a constant speed it doesn't change nor with weaving to try to load one side more than the other. Just the same wubwubwubwubwub. Speed up and slows down with speed, not dependent on RPM or Gear. Just speed. Any ideas? Seems odd to be a wheel bearing...
http://youtu.be/48tyWxnlUkw
Update: When driving at the speed I heard the noise at, I shut the car off and coasted. Heard the same noise coming from the tires in the same rotational noise pattern. got going in the car and it's like when I put a load on the driveline it reverberates the tire noise into the cabin. Swapped the wheels and tires back to my friends s2000 and he has a similar noise under load, just a lot quieter. It's still a head-scratcher as to why it's so much louder in my car than in his.
MasonPardo
24
07-23-2013 08:04 AM
