Wheel Bearing..I think?
Old 01-18-2007, 08:20 AM
  #21
NewbieS2K's Avatar
Originally Posted by greys2k,Dec 31 2006, 11:31 AM
Here are the facts
1) Noise only occurs when the car is warm
2) Happens on the Passenger side rear wheel
3) Sounds like rubbing/squeaking
4) When I hit the brakes it doesn't make a louder sound..which cancels the idea of brakes out
5) When I turn left the noise becomes louder-when I turn right..it goes away
I have the same problem except it's the drivers side and the noise disappears when I turn left haha. I had searched this problem but came up with alot of different situations. But now I know the problem/fix!
Thanks.
Old 08-23-2007, 08:38 AM
  #22
Daddycakes's Avatar
I had this same exact issue on the rear passenger side. Took it in paid about 420$. Now 14k miles later the noise started up again. Now it sounds twice as bad as before and the sound seems to be coming off both sides. Took it in to the dealer and they told me the rear drivers side bearing was destroyed. So another 420$ (Bearing and hub + labor). They also told me the left rear diff. bushing needed to be replaced (almost 500$). I passed on the diff bushing for now since I couldn't afford it and they told me that since I wasn't getting the bushing they couldn't guarantee the all the noise would go away. Now today I'm driving down the fwy and I start to hear that annoying squeek. It's not as loud as it was the 1st time but I can distinctly tell that it's coming from the passenger side.
Is this supposed to happen this frequently? The car is stock besides CAI & Exhaust.
Old 08-23-2007, 12:44 PM
  #23
J's_Racer's Avatar
hmmm does all AP1 have this problem with tightening the axle nut?
Old 08-23-2007, 02:12 PM
  #24
Billman250's Avatar
Received 1,395 Likes on 836 Posts
All s2ks, up to at least 2006, will have this problem.
All my customers get the axle nut "tsb" (really an article). One shot deal. As long as the problem has not progressed past phase 2 in my post above, it will never be an issue.
I recommend every s2k, even the new CR, to have this done at 5k miles. Torque can be lost from initial set-in.
Do it now, whatever mileage you are at. That way, you won't be a part of the weekly threads about "rear noise/clicking/rotational noise/bad bearing"
Old 08-23-2007, 02:18 PM
  #25
Billman250's Avatar
If a wheel bearing is replaced, AND the hub is good, AND it was supported correctly while pressing, AND the nut is tightened properly, it will never be an issue again.
If it is, one of the above was incorrectly done. Go somewhere else for the repair.
Old 08-23-2007, 03:12 PM
  #26
Daddycakes's Avatar
Damn. Well I'm going to call my Service advisor to make sure they did torque the nut to the proper spec. It seems like I'll be needing to replace the passenger Bearing and hub again though. Appreciate the replies Billman250.
Old 08-23-2007, 03:23 PM
  #27
J's_Racer's Avatar
hmmm so what is the best way to re-torque the nut?
Old 08-27-2007, 11:31 AM
  #28
cmn
cmn's Avatar
Originally Posted by Billman250,Jan 4 2007, 04:41 PM
Bad bearing phases
1st....axle nut not tight enough from factory (this is why we do the TSB)
2nd...clicking noises when changing direction, from axle moving back and forth in splined hole
3rd...inner races start shifting on the hub, wearing it out, causing rotational noise, low speed creaking/clicking
4th...races lose press fit on hub, shift out of alignment, and destroy wheel bearing
I have this clicking sometimes when I park and reverse etc. Is it enough to change the bearing? Or should I change the hub too?
Old 04-25-2013, 07:24 AM
  #29
beaudin223's Avatar
hi , i want to know what is the new torque spec for the wheel nuts ? i probably buy an s2k this week end and probably do this on the car just in case , thanks
Old 04-25-2013, 08:00 AM
  #30
vtec9's Avatar
Factory torque was 180ft-lb.
New torque is 250ft-lb.
Follow this DIY to perform it
https://www.s2ki.com/s2000/topic/929...le-nut-tsb-diy
The nut was marked from the factory to ensure alignment, so if your mark no longer aligns, then it was already re-torqued.
whomikedao
01-10-2014 06:02 AM
ultimaRicer
11-24-2012 05:00 AM
SeaHawk
02-18-2011 08:14 AM
J.nguyen
12-04-2008 04:40 PM
Mr. Eryozgatliyan
26
07-09-2007 01:29 PM
Quick Reply: Wheel Bearing..I think?
