wheel bearing gone bad and hub question
i was just wondering since my rear wheel bearing just went out. Is it recommended to also replace the hub out ?
You'll be able to tell if the hub is salvageable when you look at it. It depends on how bad the bearing is now, 'cause when it gets really bad it scores the hub.
Tip: Autozone stocks our rear bearings and it is a Timken for $35. Timken is one of the top bearing manufacturers so it's a good one. It's about $25 less than oem.
