Wheel Bearing
They (Zensport) a car custom shop/mecanic/friend of mine that does all the work on my car..but he did crush the nut..so I"m lost..I think i'm just gonna take it to Honda..
if it makes any difference the noise doesn't happen when I turn right...and is louder when I turn left (especially ahrd)
https://www.s2ki.com/forums/index.php?showt...39249&hl=clicks
Pretty much anything you need to know about noise coming from the rear corners of the car is contained within the thread above. Unfortunately, it is 372 pages long. What are the specific symptoms you are experiencing?
Junk hub pic. Once the axle nut issue is unattended to for a long period, the shifting inner races will destroy the hub. If you install a new bearing on a bad hub, the inner races will never hold and it will continue to ruin bearings.
The thing is I bought the car used so I don't know if the previous owner drove with bad bearings. The clicking I get is NOT accompanied with bad wheel bearing noises. The car did have an impact at the rear where the intermittent click is coming from. The axle was replaced and all linkages were inspected OK. I'm thinking maybe the splines on the wheel hub are damaged and re torquing the axle nut is not fixing this.
So Billman, is it possible the hub splines are damaged but my bearing is still good (for now)?
