Wheel Bearing
Wheel Bearing
Alright guys I have been dealing with this for a long time now..Since Feb 06..
In March I got my wheel bearing fixed...noise gone
500km later..noise back...take it back to the shop they tighten it...noise gone..
500km later..noise back...tighten again...noise back..tighten again..
Finally noise back...so I bought a new axle nut as we figured maybe the thread was done on that...new axle nut on..noise gone...and suprise.now its back..
What would make it keep loosening up?? it has been tighten to 120 ft/lbs each time...
Sorry it was 220 ft/lbs.
The bearing was replaced..I don't believe the hub was-after the bearing was taken out it looked 'messed up'...so they put a new one in...then then noise went away..since then it has been coming back and has been getting fixed by tightening and lasting abour 500kms before the noise comes back...
I'd get both the hub and bearing replaced together. Sounds like the hub's damaged which, apparently is common if you wait too long on the wheel bearing job. That whole setup is supposed to be so tight, it needs to be pressed apart and pressed together again. It sounds like the hub's damaged so, there's slop in there that works loose after 500 kms.
Last wheel bearings I did, I replace both hubs because there was clear damage on the hub where the bearing sits.
I don't think we crushed the nut..I'll try that..if not i'll replac e the hub too..thanks for the help guys..any ideas what a hub is worth? are they like $50 or $500? no idea...
Thanks!
Thanks!
Originally Posted by greys2k,Aug 7 2006, 08:21 PM
they tighten it.....
Originally Posted by greys2k,Aug 9 2006, 07:39 AM
I don't think they crushed the nut..
