whats under the Vtec solenoid?
Old 06-24-2010, 04:16 PM
MikeyCB's Avatar
On the TCT you want to retract that metal post back in, hold it with a cotter pin, install, and remove cotter pin through maintenance hole on front of engine. Not sure how to do that, but I think Billman or someone explain in a TCT thread with the term "retract." Search a little, you should find it. Or you could go spend a few bucks and buy a new one. I think I paid $25 or so for mine.
Old 06-25-2010, 11:14 AM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
You have to take the two bolt cap off the TCT, remove the oil jet with a flat screwdriver, and retract the piston with the 5mmX.80 bolt.
If not you WILL break the timing chain.
Old 06-25-2010, 09:10 PM
exodusx7x's Avatar
I understand now how to remove and install the tct.... last question, is there a way to check the tct while its removed. I have visually inspected it and it looks new. Although i have from time to time had the same noise that has been reported. im beginning to wonder if its the oil im using that may be contributing. I run mobil 1 full synth. 10-30.
Kengthao91
03-10-2015 10:43 AM
epic333
11-19-2007 11:55 AM
epic333
11-12-2007 08:09 PM
honda9krpm
09-06-2005 02:56 PM
Gink5
09-27-2004 04:42 AM
Quick Reply: whats under the Vtec solenoid?
