whats under the Vtec solenoid?
Quick question. I removed the vtec solenoid to clean it out and check resistance and thought the oiling thing under it was all one piece. Well I popped it out and realized i had no clue what it was. [/IMG] before I go firing up the engine again I wanted to make sure I wont have a problem. I assume it has something to do with more oil delivery during vtec? BtW the picture is just for reference
Nope, that's it right there Just like Juiced said.
If you're planning to remove it, be careful in doing so.
Edit: Just noticed you already removed it. I believe you're going to have to perform a little technique to get retract the spring loaded rod back in. In fact, go pick up a fresh one with a cotter pin installed and you'll have a nice new TCT to not worry about.
Well, that technically is inside the front chain cover, it's just on the side of the font chain cover, and it does not just pull out when you un bolt it, you have to compress the tensioner by inserting a M5 0.8 bolt i think it was in the maintenance hole of the tensioner to remove it..
Originally Posted by MikeyCB,Jun 24 2010, 12:40 PM
I didn't have to do that, for removal I just unscrewed and pulled it out the side. The maintenance hole is needed to pull the cotter pin out when you install/reinstall.
Ok so let me get this straight. I popped out the tct..... looked at it. went ohh crap.put it back in and bolted it up.... Should I pull it back out and rebuild it just for good measure? im sitting at 110k.
I haven't fired up the car yet since I'm still going to clean out the vtec solenoid.
uh oh. There are quite a few pieces inside of the tct. A couple springs, worm gear, piston etc. First hopefully you didn't drop any of those pieces inside of the chain case. Second its probably putting ALOT of pressure on the chain guide and will most likely cause some extreme wear on it fairly quickly. I'm not an expert on tct's but I would remove it and either purchase a new one, or take that one to your local honda dealership to have retracted and pinned.
