what's normal oil temp and pressure on N/A s2k?
hi guys
I just installed oil temp and oil pressure gauge on N/A s2k
on the way back home, temp was like 105 c and pressure was like idle 2bar to full throttle 6 bar. (metric gauges) I didn't drive crazy or anything .
I put the sensors on sandwich block (oil filter location)
what would be the normal pressure and temp on N/A s2k ?
I'm running 5w40 motul syn. with OEM filter.
Thanks in advance!
Thanks in advance!
my oil temp will range from 180F (winter) to ~230F (extreme summer heat highway driving) but it all depends on the weather and how I drive.
My oil pressure is usually 60-85 psi driving at above 3k rpms.
depends how hard u drive.. cruising down the motorway @110kph prob ~100c
can't remember wat the oil pressure is..will have a look next time
your pressure sounds like normal tho...i think my pressure does get to about 7bar driving hard but mostly 6bar usually
cheddaboy
12-06-2015 02:41 AM
Spoolin
05-16-2010 08:43 AM
