What's with my 2-3 shift? (solution)
Old 07-12-2013, 03:13 PM
XxMerlinxX's Avatar
Default What's with my 2-3 shift? (solution)
So for a while now, I've felt like whenever I complete my 2-3 shift, I'm hitting something as it goes into gear. It does this sometimes when I shift as slowly as possible, even when I center the shifter before pushing up into the gear, and more so when I try to shift quickly. I tried replacing the clutch fluid and that didn't help. The only thing that seems to make it go away is if I double clutch before shifting, which is annoying. My clutch rod was horribly under spec, with lots of play in it, so I tightened it up as much as possible and then eased it back to where there's no play but not over tightened. It helped my 1-2 shift and made the clutch feel a lot better when engaging, but did not help the 2-3 clunk. Any ideas what this could be or what could help it? This is on an '02 with about 49k miles, btw.
Old 07-12-2013, 05:00 PM
trep's Avatar
I'm having the same thing as you. I was about to change the transmission oil (it has to be done anyway) and see how it was after that.
Old 07-12-2013, 07:51 PM
XxMerlinxX's Avatar
Yeah, I changed all of the fluids a while back, didn't help much with this problem. I'm stumped.
Old 07-13-2013, 12:22 AM
AZ-S2000's Avatar
There have been some DIY for re-greasing the shifter. Give it a shot? https://www.s2ki.com/home/2010/03/11...rease-shifter/
Old 07-13-2013, 03:04 AM
Saad_Z's Avatar
Is there a TSB for re-greasing the shifter?
Old 07-13-2013, 08:44 AM
QuangNguyen_89616's Avatar
try shifting at 5-6k rpm
Old 07-13-2013, 09:54 AM
JeffHolmstrm's Avatar
I think its normal i have it when shifting from second to third gear, i read somewhere at shifting at 4-5 rpm helps, and it dose at least for me, i don't care so much about it though.
Old 07-13-2013, 03:15 PM
AZ-S2000's Avatar
Originally Posted by Saad_Z
Originally Posted by AZ-S2000' timestamp='1373703739' post='22663599
[quote name='XxMerlinxX' timestamp='1373687499' post='22663406']
[/quote]
I'm not sure.
Old 07-13-2013, 03:22 PM
lleron's Avatar
It's most likely your 3rd gear synchro. Mine's done the same thing sporadically since I got the car at 26k miles. I changed my transmission fluid to the Amsoil fluid, which helped a bit, but it's still sometimes there on shifts. I don't think there's really much you can do to fully solve the problem short of rebuilding the transmission.
Old 07-14-2013, 08:20 AM
Yoni's Avatar
I was having the same problem and changed the transmission fluid to the Amsoil that a bunch of people recommended. For the first several days, it felt the same. Then, I slowly realized that the problem went away. Was told it can take a while for old fluid to drain out. Before you start rebuilding anything, try this. Worked for me.
Quick Reply: What's with my 2-3 shift? (solution)
