whats the difference between bare ap1 & ap2 blocks
Originally Posted by raffiawakim,Feb 21 2008, 05:51 PM
that was definitely the answer i wanted to hear.. when i do install the new block i will start the boost at 1 bar and see what happens on the tune..
bottom line, its beneficial to install the built block and forged pistons...correct?
with boost of course..
If a sleeved block is done right it has to be stronger than stock, just because of the thicker iron and (possibly) closed deck. I do not know what the bore size limit is for F20/22 engines, but too much of an overbore leaves little deck surface for a gasket to seat in the little pinch between cylinders, and this makes for problems. This is why many people o-ring their blocks.
You (or your friend) says the block "can handle 30 lbs". What is the manufacturer of the sleeves? Where does this number come from? Is it tested or just an estimate? Bigger bores means less metal means less bore stability/strength.
But IF the quality is there, then it is beneficial if you want to run significant boost.
Originally Posted by Amphibian,Feb 22 2008, 11:24 AM
No, he will only increase it by 100 cc:
I am assuming if he plans to go FI he would use his friends block, the question is does he go to the trouble of rebuilding it with his crank of rods.
