whats the difference between bare ap1 & ap2 blocks
Old 02-21-2008, 09:37 AM
raffiawakim's Avatar
Default whats the difference between bare ap1 & ap2 blocks
ok, here is the run down.... i have an ap2.. a good friend of mine has an ap1 with a built bottom end.. he is taking the built bottom end out and putting a stock bottom end in. he is giving me the sleeved block and 89mm forged pistons... my question is, will i be able to install MY ap2 crank and rods over to his built block and forged pistons??
the forged pistons are for FI. the CR is 9.25:1
Old 02-21-2008, 12:28 PM
AusS2000's Avatar
It's certainly possible. The only real difference is the crank and rods.
But it's a hell of a rebuild. You'll want to do bearings at the same time.
And to what effect? Are you going FI? If not it's a waste.
Old 02-21-2008, 12:37 PM
I will be going FI soon. i dont plan on doing the swap until i get my turbo kit. i also plan on changing the bearings as well. i work at honda so i get a smoking deal on parts. my friend says the block is good for 30psi so i think i will be pretty safe... since the crank is out of the 2.2, does that mean i will still be a 2.2?
Old 02-21-2008, 01:32 PM
AusS2000's Avatar
Yep, 2.2.
On one side of the argument why bother. You'll be going to a whole lot of trouble to up your capacity 200cc and lower your redline. Probably increase your power by as much as a raise of 0.1psi would when turbocharged.
On the other hand, you get parts cheap!
Old 02-21-2008, 01:54 PM
Originally Posted by AusS2000,Feb 21 2008, 02:32 PM
Yep, 2.2.
exactly...lol.. on the other hand, on a stock block i can only push 8psi max whereas on the block my friend is giving me i can run up to 30psi.. and in addition, i will be also getting the forged pistons that have a lower compression ratio... so both the pistons and the sleeved block will allow me to run alot more boost...
Old 02-21-2008, 02:00 PM
AusS2000's Avatar
I wasn't suggesting you shouldn't use his block and pistons. I was suggesting you use his whole short block rather than rebuild with your cranks and rods.
But if you have cheap access to parts and a competent engine builder go ahead.
Old 02-21-2008, 03:45 PM
silvers2k01's Avatar
love the google ads for curtain rods
Old 02-21-2008, 04:24 PM
Amphibian's Avatar
Yep, 2.2.
No, he will only increase it by 100 cc:
(8.9/2)(8.9/2)(3.1415)(9.07)(4) = 2257 cc instead of 2157 cc (AP2)
(radius squared)(Pi)(stroke)(# cylinders)
A 89mm piston couldn't weigh that much more than a 87mm stock piston, especially if it is forged, especially if it has less material in it like a lower-compression piston must.
Increasing stroke will lower redline due to higher piston speeds. A much larger piston would be needed to make its mass test the rod/crank strength.
what WILL kill your power is the lower compression, until you massively overcompensate for it with the turbo.
Old 02-21-2008, 04:51 PM
that was definitely the answer i wanted to hear.. when i do install the new block i will start the boost at 1 bar and see what happens on the tune..
bottom line, its beneficial to install the built block and forged pistons...correct?
with boost of course..
Old 02-21-2008, 05:31 PM
Slows2k's Avatar
If the shortblock is already assembled, I wouldn't swap crankshafts and rods to have to redo all the bearing clearances for the different parts.
No 2 blocks or cranks are exactly the same, and the bearings will change between them.
Quick Reply: whats the difference between bare ap1 & ap2 blocks
