What wire to tap 4 air/fuel gauge?
I have a 3 wire autometer air/fuel gauge that I want to install. What wire do I tap into off of the O2 sensor???? If I am right I think it is the 02 sensor that is closest to the header right??????? Anyone know a good place to tap in????????ie somewhere under the hood instead of under the car???????
Thanks Kenny
Thanks Kenny
I suggest you tap in at the ECU. This makes the wire run much more convenient and simplistic.
You need to pull the 31 pin connector from the ECU and find pin #16. This is a solid WHT wire. Tap into this one.
Originally Posted by KenGPW,Aug 5 2004, 05:04 PM
Thank you.... Is that the same connector that I wired the ESM to?????
