what transmission and diff fluid should I use?
Old 01-16-2014, 10:19 AM
iamxpl's Avatar
should be just fine. just as long as you follow the Billman Gravity feed procedure you should be ok. Happy motoring!
Old 01-16-2014, 11:19 AM
redlineracing's Avatar
Yep...Valvoline is good stuff.
\rlr
Carolina
Old 01-16-2014, 12:09 PM
s2kking's Avatar
Thnx for all the info
Old 01-16-2014, 02:06 PM
SheDrivesIt's Avatar
I understand that Dot3 and Dot4 are not incompatible (hence the DOT3/4 designation on the DOT4) it's just that if you mix the two, the boiling point is still the lower value (more of an issue for your brakes than your clutch). Do not mix Dot 3 or 4 and DOT5. They are not compatible. I and many others have used the DOT4 (DOT3/4) Valvoline.
Old 01-16-2014, 02:14 PM
INDYMAC's Avatar
I like the Valvoline Dot 3/4, but I would use any rated DOT 3 or 4.
I like Amsoil MTF too.
But I'm surprised that no one has mentioned LE1605 for the diff. It is the best gear oil you will find for the S2000, period.
Old 01-16-2014, 03:25 PM
Dezoris's Avatar
LE1605 is great unless you plan on driving below 30 degrees when the oil ceases to flow. Its a a great if not best choice for summer.
I run Motul 300 in diff now more versatile in different climates.
Old 01-16-2014, 03:40 PM
lude92_si's Avatar
Amsoil 75w140 in my diff. but its a built stage 2.
Honda MTF in the tranny.
Old 01-16-2014, 05:29 PM
JDMhondaS2K's Avatar
Transmission = ams oil synchromesh
Diff = ams oil 75-110 severe duty gear oil.
The trans seems to be easier to shift since I switched but it could be just my imagination.
Sent from my HTC6435LVW using Tapatalk
Old 01-16-2014, 06:25 PM
TommySalami's Avatar
AMSOIL MTF feels the same as Honda MTF
GM Synchromesh FM shifts a little better when cold if you have notchy shifting but is not as smooth when the transmission is hot
People seem to really like the Redline MTF, but I have yet to try it
AMSOIL severe gear is great for the diff
Hi.s2k
02-23-2012 04:21 PM
mikedaboss2k
17
11-27-2011 04:42 PM
Sub_01
05-20-2009 07:08 AM
SaV
11-11-2001 08:14 PM
Quick Reply: what transmission and diff fluid should I use?
