what transmission and diff fluid should I use?
Old 01-16-2014, 06:37 AM
s2kking's Avatar
Default what transmission and diff fluid should I use?
Ive read on online a few ppl saying not to use honda fluid because it damages the diff nd tranny is this true??? I need to change my fluids asap but dont know what brand to go with
Old 01-16-2014, 06:57 AM
darcyw's Avatar
transmission- Honda MTF or amsoil trans fluid.
Diff- Amsoil 75w90 or 75w110 severe gear synthetic, or mobil 1 75w90 or 75w110 gear oil, or...just check that its compatible with limited slip differentials.
there's lots of references to your post throughout this forum as well.
darcy
Old 01-16-2014, 07:24 AM
iamxpl's Avatar
^^^ what darcy said. the only way honda fluid will damage the diff is people end up with the CRV diff fluid. just use the trans fluid if you want. i use amsoil everything.
Old 01-16-2014, 07:25 AM
s2kking's Avatar
darcy
Thnx for the info
Old 01-16-2014, 07:26 AM
s2kking's Avatar
Thnx
Old 01-16-2014, 07:28 AM
s2kking's Avatar
One more question can I use any dot 3 brake fluid for the clutch fluid??
Old 01-16-2014, 07:58 AM
Iniamyen's Avatar
Yes. Just don't mix DOT3 & DOT4.
Old 01-16-2014, 08:08 AM
redlineracing's Avatar
I recommend & use these products in my 03S,02Z06 & 96GST. Oil,Trans & diff.
Clutch & Brake I use/recommend Prestone Dot4.
As the Food lion says "That's just my 2 cents"
If I can help you,let me know.
\rlr
Carolina
Attached Thumbnails what transmission and diff fluid should I use?-azo-0w30.jpg   what transmission and diff fluid should I use?-mtf.jpg   what transmission and diff fluid should I use?-sg-75-110.jpg
Old 01-16-2014, 08:29 AM
iamxpl's Avatar
i use Motul RBF600 for clutch and brake. but i will be switching it out to ATE super gold.
Old 01-16-2014, 09:21 AM
s2kking's Avatar
Well the brake fluid I was gonna use is Valvoline brake fluid Dot3&4 is that ok and its synthetiC
Quick Reply: what transmission and diff fluid should I use?
