what suppouse to be?
hallow guys . .
what suppouse to be the right throtel position reading in %?? . . because i had the idle @ 5% and the wide open was @ 92% . . dose this seam right??
Originally Posted by hecash,Nov 29 2005, 02:44 PM
I would expect to see 3-5% at idle and 96-99% at WOT.
So, your readings are very close to my expected result.
What is your purpose for tracking these settings?
WhAT HAPPEND IS I FEEL LIKE THE CARS PERFORMANCE IS BETTER BUT AT IDLE RUNNING THE RPM IS NOT STABLE ...
1st, Turn off the Caps Lock. Spelling in all Caps makes it difficult to read, and lets everyone know you are shouting.
2nd, put the TPS sensor back where you found it. Advancing the TPS sensor will do exactly what you have found, cause an unstable idle speed.
