What size philip to use to remove "Map Sensor" ?
Hi guys,
Last summer, my car was chocking when i tried to accelerate from 0 MPH.
researched and realised i have the "whack map sensor" problem.
I wanted to clean whats under my map sensor today but i failed because i coulnt
remove the map sensor. I tried few of my screw drivers, it doesnt seem to have enough
torque.
What size philip should i use? My bolts are quite tight =/
Thank you.
torque.
Thank you.
Former Sponsor
Just try a quick hammer hit on the end of the philips screw driver before unscrewing. As long as it fits shouldn't be a problem. Might just be seized or something.
i tried to use philips but it seems they might damage the bolt.
They look really fragile those screws , i even used a ratchet to give more torque but no luck. I guess i dont have the right philip head?? Or maybe , previous owner used different screws..
When i tried breaking them loose, if i applied downward force + twisting motion, it would just strip them and they wouldn't come loose.
When i just applied light pressure + twisting, they came right off... makes no sense.
seansniper
06-20-2012 08:35 AM
