what size in mm
what size in mm
I was going to change the fluid in my differential today, but noticed the filler plug, and the drain plug was huge, non of my tools fit. Does anyone know the size of these two plugs in mm?
Thanks in advance.
Thanks in advance.
I believe the drain plug is a 22 mm, but I could be wrong. I can't exactly remember what size the filler plug is, but I would imagine it's smaller than the drain plug. If I'm not mistaken, that bolt is pretty thin from what I remember, so you might want to be careful taking it off. Hence, don't let your hand slip when unturning the bolt.
