What size is the bolt that the oil filter
Hey guys, does anyone know what size the bolt that holds on the oil filter is? I have 32 an 36mm sockets at my house and I know that it is in between those two because the 32 is too small and the 36 is too big. Anyone know what size it is? I tried to search, but I don't know what that bolt is called. Thanks.
Sorry, I wasn't specific enough. I'm talking about the bolt that comes out of the block and holds the stock oil cooler and the oil filter screws into. I want to remove the stock oil cooler, but I need to know what size that bolt is. Do you understand which one I am talking about now? Thanks
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
I measured the one I have out back the shop on the stand and get 30mm ( actually it comes out to 29.8mm on my verniers )
Not sure if they have used different sizes through out the years , but you say that your 32mm does not fit??
![confused.gif](https://www.s2ki.com/forums/images/smilies/confused.gif)
Could it be the depth of you socket?
I have 4 more motors here but they have been stripped down . All the bits have been put into separate crates . I will pull them down tomorrow and check to see if they are different .
Twiztid, I just went to the store and bought a new 32mm socket because it looked bigger then mine for whatever reason. Turns out that the new one worked fine, but my old deep socket is too small
. Doesn't make any sense, but thats the way things go some times. I appreciate you taking the time to help me out.
For anyones future reference the oil cooler center bolt is 32mm. Thanks.
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
rrounds
01-12-2012 12:17 PM
