What performance spark plugs and wires should i use???
I am a believer in using colder plugs. I use the IK24s with my nearly stock setup, and it doesn't seem to suffer much loss during hot days. I have also seen via ODBII that my '02 runs about 10% more timing advance than my friend's '02. His setup and mine are almost identical except for the plugs.
[QUOTE]Originally posted by Windscreen
The only way a spark plug could cause a timing difference is if the hot plug is so hot that it is causing preignition and then knock because of the preignition.
