what is this noise, and where is it coming from?
Old 02-20-2010, 02:11 PM
Fredster's Avatar
Default what is this noise, and where is it coming from?
So I've had this whistling/whine noise coming from around the driver's side headlight for about a week now. the sound first started on a cold morning and stops every time i rev the engine but as the video shows it comes back up again. at times it smells like something is burning.
i currently have a CEL for the TPS which i would think has nothing to do with this sound. and i know i need a tct
[media]http://www.youtube.com/watch?v=T9fo0J9LxwM [/media]
Old 02-20-2010, 02:16 PM
zeroptzero's Avatar
Received 3,799 Likes on 2,677 Posts
the air pump is right there and engages on cold start up only. The likely source. They do fail after a while, or something could be disconnected.
Old 02-20-2010, 02:18 PM
Fredster's Avatar
so you think it's the air pump? because even when my engine is fully warm, the sound continues. every now and then it will stfu.
Old 02-20-2010, 02:21 PM
suzuka-blue-s2k's Avatar
Yeah it kinda sounds like your airpump might be going bad. Mine started turning on and off randomly then blew the fuse. I had to buy a new one from here. I had the CEL for it though, it was the P0410 code if I remember right. Man you must have bad luck! I just sold you that knock sensor you had a CEL for!
Old 02-20-2010, 02:26 PM
Fredster's Avatar
LOL! Yeah I know, that knock sensor was my own fault when I replaced the clutch. I replaced the sensor, had the pleasure of not seeing that CEL for about a week and bam! Got another CEL. I'm heading to Autozone, maybe I do have the code.
Old 02-20-2010, 02:28 PM
Wow sorry to hear man! Yeah pull the codes and come back and let us know whats up.
Old 02-20-2010, 02:32 PM
FitzyS2k's Avatar
wow your engine is really chatty. that TCT sounds really bad. have you checked the oil and made sure it's at the level it should be? my TCT is a lil noisy once the oil level is low. i replaced it last summer.
Old 02-20-2010, 02:45 PM
Fredster's Avatar
trust me, i check my oil weekly as i'm running mobil 1. AP1's and Mobil one =
Old 02-20-2010, 02:58 PM
FitzyS2k's Avatar
yeah my engine starts to make noise around 3k miles. plus i'm anal about changing my oil at 3k miles
Old 02-20-2010, 04:06 PM
Slows2k's Avatar
Doesn't sound like a bad tensioner to me.
Quick Reply: what is this noise, and where is it coming from?
