What is the lift up Thing in Center Console
Old 11-08-2009, 09:20 AM
zeroptzero's Avatar
Received 3,714 Likes on 2,630 Posts
Default What is the lift up Thing in Center Console
Just curious, what is that lift up tab that is in the cupholder area of the center console ?, I can't figure it out. I didn't see it mentioned in the owner's manual. I feel dumb for asking this but it has my curiousity. My 02 came with an AP2 center console, so perhaps it is something that wasn't on the 02 console ?, dunno. Thanks for any replies on this.
Old 11-08-2009, 09:37 AM
CKit's Avatar
Push on it to have it flip up. It then holds a cup. Push to flip it down and you can hold a sammich. Is that what you're talking about?
Old 11-08-2009, 10:24 AM
zeroptzero's Avatar
[QUOTE=CKit,Nov 8 2009, 10:37 AM] Push on it to have it flip up.
Old 11-08-2009, 12:29 PM
CKit's Avatar
It's supposed to be spring loaded. You don't pull up on it. You push down and it springs up. That may have been part of the problem. If someone pulled up on it, they could have broken the latch mechanism. Or perhaps it got messed up in the retrofit.
Old 11-08-2009, 03:07 PM
mister x's Avatar
Don't steer this guy wrong, it's the secret switch, lets you rev to 8000 RPM in an AP2.
Old 11-08-2009, 03:12 PM
zeroptzero's Avatar
yeah I have to lift it up in order to get it out of its slot, then it just drops back into place, it is no longer spring loaded. That sucks, some would have broken it in the past then. I may take a look at it when I pull the center console to lube my shifter in the near future, maybe the spring is still in the part somewhere underneath. Thanks for the reply to such a small concern.
Old 11-08-2009, 04:49 PM
SgtB's Avatar
It should go "click, click" when it latches and unlatches.
Old 11-08-2009, 05:25 PM
CKit's Avatar
FAIL. Have you checked what the redline on an AP2 is?
Old 11-08-2009, 05:30 PM
Greg W's Avatar
Thought it opened the other secret compartment, the one I can' find...
Old 11-09-2009, 04:28 AM
rudeboy1313's Avatar
dont worry, it took me 30 min to find the gas latch on my s2k. Did you find that yet. and forget about the secret door, i found that by mistake. I was like,," what the hell is this" trueeeee..
Quick Reply: What is the lift up Thing in Center Console
