what kind of spring is this?
Hey guys, so I noticed a puddle of oil in the driveway. After looking everything over it seems that my front shock has finally blown. It seems the previous owner installed ground control sleeves on the car. I would like to put on koni yellows, I know that ground control makes a different kind of sleeve but they only sell everything as a kit.
I would like to know what kind of spring this is and I also need to know the spring id.
I was thinking of using a koni threaded sleeve kit.
http://www.jegs.com/p/Koni/Koni-Spri...18160/10002/-1
does anyone know the spring id, I guess its how many MM like 40mm or 2.25inch something like that
DOES ANYONE KNOW WHO THIS SPRING IS MADE BY?
![](http://www.freeimagehosting.net/t/6qltm.jpg)
![](http://www.freeimagehosting.net/t/whohg.jpg)
So you're expecting us, as members to look at you picture and tell you for sure what springs you have and what size they are?!?! Get out of here....seriously, no one is going to be able to definitively tell you what you have...
![egads.gif](https://www.s2ki.com/forums/images/smilies/egads.gif)
![banghead.gif](https://www.s2ki.com/forums/images/smilies/banghead.gif)
just asking for some help, maybe somone knows. Ive called ground control who told me I have a knock off kit. I called koni and they said that all they need is the spring id to figure it out. So far they gave me 2 part numbers that will work, but I need the right spring id.
for sleeve they gave me 80.0000.005
for perch its 80.0000.005
Okay....we CAN'T TELL YOU THE ID OF YOUR SPRING!! Get yourself some McPhearson Spring compressors and measure the spring yourself. We can't help you with that. It is IMPOSSIBLE to look at your picture(s) and tell you what size spring(s) you have.
maybe u cant, but someone else can, maybe someone else has the same setup.
Why are you acting like a little girl, "We cant help you" other people are getting helped when they have a question
I help people all the time whenever possible, member or not. Acting like a little girl? Please. It's people like you that make me wish the Under the Hood section was members only. NOBODY is going to definitively tell you what size springs you have. That's all I'm saying...
