What happened!?
What happened!?
Did an oil change. Oil, 5 quarts, K&N filter, lower her down, start her up...
oil light flickers and i shut her off immediately..... then OIL ALL OVER THE FLOOR. Its not the plug, and not the filter.... WHAT HAPPENED!!?!?!? This is obscene! I've done 8734958 oil changes... what on earth could i have done wrong... help me!!
Old filter gasket sandwiched between your new filter? Did you hand tighten the filter? They're supposed to be turned another 3/4 turn with a wrench once they're hand tight.
Originally Posted by Stu A.,Apr 5 2007, 07:08 PM
... Its not the plug, and not the filter.... WHAT HAPPENED!!?!?!? This is obscene! I've done 8734958 oil changes... what on earth could i have done wrong... help me!!
My best guess is that it's one of three things:
1. The old o-ring from the filter stuck to the flange where the oil filter mounts. I've never done this, but have heard of prodigious leaks when the new o-ring tightens against the old one.
2. Between the time you wiped a drop of oil on the o-ring of the new filter and the time you tightened it, the o-ring came off the new filter. I've done this one. I can't describe it without using the words "Exon Valdez."
3. The oil filter is nowhere near tight. Worst case, it's cross-threaded and got hard to turn before the o-ring sealed.
You wouldn't get a gusher with the drain plug in place, even if it weren't tight. That would drip, not gush. The filter is under pressure and will gush.
Originally Posted by RedY2KS2k,Apr 5 2007, 04:31 PM
you left the oil fill cap off and turned the car upside down.
5 quarts is TOO little for a complete oil change. how much oil are we talking about on the ground here?
perhaps you missed the hole where you pour the oil in...did you get distracted and pour it all over the place and then accidentally pour in the hole when you looked again?
Originally Posted by jyeung528,Apr 5 2007, 07:52 PM
this was fuqing funny.
Originally Posted by RunUrAss,Apr 5 2007, 04:56 PM
c'mon folks..give this guy some credit afterall he did do 8734958 oil changes ...i have nothing informational to say regarding this...my next response probably would have been the oil fiter being on too tight or not tight enough
Originally Posted by jyeung528,Apr 5 2007, 08:02 PM
maybe he is over-estimating the number of oil changes he has done?
