What gauge or wire is needed for 24V at 600amps?
#21
Originally Posted by gernby,Sep 2 2004, 01:39 PM
For racing applications, I would think hybrids would be way too heavy whether you are using capacitors or batteries. Gutted race cars with race prepped engines probably produce much higher hp / lbs than a hybrid system.
Capacitors might work(I think they have a fairly high enery/lb rating), but charging them and storing enough energy will be a challenge....
#22
Storage capacity per pound is definitely MUCH greater with batteries. The only advantage to a capacitor is that it can charge and discharge very quickly. I doubt you could even fit a capacitor in a car that would provide 600 amps at 24V for more than 1 second before it was completely discharged.
#23
But there is new technology in the pipe, it remains to be seen if it will work but it has potential...
http://abcnews.go.com/sections/SciTech/Fut...h_040810-1.html
#24
You guys are getting exotic enough that I don't know why you don't go all out: a gas turbine engine hybrid.
The main problem with a gas turbine engine is that the lag time is too slow. So decouple it from the drive train by using an electric motor. Step on the pedal and the electric motor spools up fast (drawn from a capacitor, maybe). The gas turbine spools up slower, but fast enough to replace the power in the capacitor. Something like that.
#25
I'm holding out for the Mr. Fusion that will charge the flux capacitor that drives my 2000 HP electric AWD S3000.
EDIT: A big part of my concept (named the Gern Mobile) is that it will not have a frame or body panels. All the essential components (including myself) will just be suspended by a force field. The total weight of the vehicle will be a scant 452 lbs including fuel (garbage). The exterior design will be flexible, since it will just be a hologram.
#26
jsenclosure
Member S2000 Classifieds and For Sale
01-29-2012 11:12 AM
