What is gained by injector size
Is there anything to be gained by changing out the stock injectors to larger ones on a N/A engine. As for mods a Spoon Snorkle, gutted and insulated airbox, 70mm TB, intake manifold ported and polished ot match the TB, Hondata gasket, Berk header. Will complete exhaust once I find what I want.
My goal is to buiild out the engine without going F/I.
Thanks in advance
Thanks in advance
To make more power, the engine needs more air.
The ECU adds more fuel when the MAP sensor detects more air being breathed in by having the injectors open for a longer duration. Only when the injectors are open "all the time" do you need bigger injectors, or a higher fuel pressure. Both modifications can also have their downsides at lower rpm / power levels.
As someone said above, the stock injectors seem to give you enough fuel for 350hp (can't confirm that but sounds reasonable), so there's no point in changing them out unless you are going higher than that.
Basically, adding more fuel is trivial, but adding more air is very difficult.
-Marin
-Marin
