What does valve chatter sound like?
My guess is I need to get my valves back in spec, as I'm thinking their making some noise, but I'm still kind of a noob on the whole diagnosing thing. I drove with the top up today and noticed a noise that for lack of a better description: sounded like a nest of birds chirping (though not nearly as loud).
Symptoms:
- From about 3K+ you hear it, although from that point when it becomes audible the noise doesn't seem to noticeable change w/ rpms.
- Doesn't make it in neutral
- Sound stops when braking
- Only when under cruise / accel
I'm the 2nd owner, now has about 54k on it. My educated guess is leaning towards the valves, or feel free to correct me.
Thanks
Symptoms:
Thanks
doesn't sound like valves to me.
out of spec valve clearance usually is loudest at idle and sounds more like small soft clicking/tapping. not chirping as you mentioned earlier.
also, the noise would NOT be effected by braking or trans gear.
Any ideas then? Could it have been being low on oil? I checked and it was a little above the L, I threw in about half a quart to hold off until my oil change this week
