What does notchiness feel like?
I have heard that our s2000s will be "notchy" in the cold going from 1 to 2 and 2 to 3. Well Firstly, how cold is cold, because I will feel it being "notchy" unless its about 80 degrees F. Also it feels like a single grind, and the one from 2 to 3 is evident more often, no matter the temperature. I changed my tranny fluid about 4 months ago and they said there wasnt anything in the fluid, so im not sure whether I should be worried or not? This will not occur if i go from first gear, then clutch then neutral then let off the clutch pedal, then back on the clutch then shift to 2...
DIY courtesy of Saki GT:
https://www.s2ki.com/forums/index.php?showt...&#entry17483619
Actual Honda TSB:
https://www.s2ki.com/stor/library/TSB/A02-046/index.htm
You probably want to get some rubber gloves for this. It's a bit messy.
Actual Honda TSB:
there are no leaks, and I have checked the clutch fluid, unless i am checking the wrong canister. I just want to know what notchiness feels like, because i let a mechanic drive it and he said nothing was wrong, but i just dont know if i believe him
go drive an STI, DSM, 3000GT, old school supra, or a mustang. that's what notchiness feels like
a notchy shifter feels like it's fighting you a bit when you're trying to shift. picture churning butter, without the butter. the word i would use to describe it is really more clunky than notchy.
