What Do You Use To Fill Your Differential and Tranny
Old 11-11-2013, 11:58 AM
zeroptzero's Avatar
Received 3,543 Likes on 2,545 Posts
Originally Posted by daktruckie99
I use about 4 feet of long clear tubing. I slide underneath the car and hold the tube in the fill plug while my wife pours the fluid from above.
-Mike
yup I got the little woman to help me too. My clear hose fits nice and tight into the fill holes of the diff and tranny, once I get the hose inserted it is pretty easy as it stays inserted until I am ready to pull it out. The trick is keeping enough slope on the hose going to the diff so gravity can do it's job with the thicker fluid. I tend to overfill the sumps with 2 bottles of tranny fluid and one bottle of diff fluid, so as soon as I pull the hose the excess drains out - keep a pan underneath.
Old 11-11-2013, 01:31 PM
s2000maniac's Avatar
What size clear tubing?
Old 11-11-2013, 01:55 PM
zeroptzero's Avatar
Mine is 1/2 inch inside diameter, and about 5/8" outside diameter. I found funnels that fit inside the hose perfectly, the funnels I found came with short vinyl tubing, I just pulled them off and put on the longer hose. I bought 8 foot lengths but cut them down to about 6 foot each, one for the diff fluid and one for the tranny.
Old 11-11-2013, 02:20 PM
Ok thanks
Old 11-11-2013, 02:24 PM
fernando.'s Avatar
Old 11-11-2013, 02:35 PM
Themikewoo's Avatar
I work in the medical field and use a 60 mL syringe.
Old 11-11-2013, 03:39 PM
zeroptzero's Avatar
Originally Posted by fernando.
That's a nice pump setup, better than what you can find over the counter.
I still prefer to dump into a funnel and avoid pumping at this point.
Old 11-11-2013, 06:10 PM
Forcedbird's Avatar
Harbor Freight pump user here too!
http://www.harborfreight.com/multi-u...ump-66418.html
Old 11-11-2013, 06:48 PM
darcyw's Avatar
Originally Posted by Forcedbird
yup. works well. After use, i clean it with simple green and store it in a zip lock for next time. works very well to get the fluid where you want it.
good luck.
darcy
Old 11-12-2013, 03:26 AM
Billman250's Avatar
Received 1,338 Likes on 810 Posts
I screw the gear oil top onto the MTF bottle and shoot it directly out of the bottle. Very fast and mess free.
Quick Reply: What Do You Use To Fill Your Differential and Tranny
