What to do while the motor is out
This.
Motor mounts is a good one too (that was already mentioned.)
Maybe new starter.
But if you're making the investment on a new engine, I assume its new(ish) coils, plugs, valve springs, seats, etc. Those would all be good to on the engine itself.
Maybe clutch fluid since it would be easy to get to, many people forget about that one.
Maybe new starter.
No way I'll do a tuck, the banjo bolts I mentioned are the same thing as oil jet bolts. Im and em gaskets are for sure. And since I took my header off, I will replace the donut gasket as well. The starter on my old motor is only a couple years old. I've already been practicing drinking beer for years so def gonna have to beer mod. Other things though were mentioned that I hadn't thought about and that's why I made this thread!
Originally Posted by JFUSION' timestamp='1369013597' post='22553556
I would put in a new ap2 oil pump, 4 hole oil jet bolts, and new or low mile ap2 starter. These are things that are easy to do when the motor is out , but not so easy later down the road. The oil pump will give you some peace of mind compared to a used one. I did this when I replaced my factory f20 last year. While the tranny is off consider doing a new clutch if yours has some miles on it.
So, I've had a lot of people make suggestions about other things to do/replace when I pull my blown motor and reinstall another one. I'm already going to be doing a couple other things but was looking for more suggestions/ideas. Car is a MY01 with 155k. Going back with another f20.
