What to do if car is running too rich
I've noticed on startup that the car seems to be running a little on the rich side. You can smell the unburnt gas, and there is also a slight amount of smoke after cold starting. This is also coupled with a slight hesitation when reving the engine (not hard reving, just bumping the throttle). Wanthing to know if this is something that could be fixed by resettng the ECU, or is there something the Honda place can do to lean the fuel up some. Or is this normal? I've also considered changing plugs.
Thanks
Thanks
S2000's generally run rich. That's just the way they are. Also, blipping the throttle just after a cold start, while the engine is trying to stabilize its own idle is not indicative of any particular issue.
