What do I do from here?
are you boosted ?, the only thing I can think of that would cause that would be detonation. If that's the case the internal parts could be in bad shape. Interested to see if it starts up and runs like normal once you get it going.
I stuck a magnet inside the cylinder and found nothing so the plug tip that broke off, yes the tip of the plug broke off into my cylinder, is gone. I put in a new plug but it only threads in about half that of the others. It goes in mighty tight, but the half threading scares me a little. A mechanic friend of mine told me to tap the threads with the same size tap (same size as the plugs). My questions is this: Do the threads for the spark plug go to the edge of the head? Basically, if I use the thread tapper is it ok to go all the way through? I've had to use a tap and die set on some body work before but never dealing with the motor.
P.S. Found a coil pack from majestic honda for only $107 shipped
Last week we had a compressor tester get stuck in the head. Took two days of crazy happenings to get it out.
Don't give up, it took us 2 days but we didn't let the tester kick our ass
splatter85 Posted: Nov 21 2010, 04:04 AM
splatter85 Posted on Nov 23 2010, 06:36 AM
Sound a bit like going from bad to worse......
As far as I know the spark plug threads are trough & through.
Well the coil pack disappeared... I got to the plug and it tugged right out. I put in a new plug and the threads on the head are still ok some how. It screwed in like normal.
I would look into having a "Time sert" installed as you will most likely find that the bottom half of the thread in the head got melted into the spark plug, and was dragged through the top half of the thread as the plug backed out.
There is a trick with the time serts. Put the piston at BDC on the firing stroke, fill the cylinder with shaving cream ( use a tube), install the time sert then turn the engine to TDC. Any swarf/debris from the installation will be pushed out by the shaving cream.
