What differential Fluid do you use
So i went into the Honda dealer last week to buy Honda trans and differential fluid. I bought the trans fluid no problem but they had no "OEM HONDA" fluid recommendation. That kind of bothers me because im the type that uses what Honda tells you to use. The guys in the shop said valvoline but im definatly not a big valvoline fan.
What are you guys using sence Honda has no recomendation?
Redline?
Royal Purple?
Mobil1?
Redline?
Royal Purple?
Mobil1?
I use LE 607 (SAE 90), but will have to switch over to LE 1605 (SAE 110)on my bext drain and fill (LE 607 has been discontinued).
Since you live in Wisconsin (Arctic), AMSOIL SVT 75W110 would be my first choice if I drove during the winter at all.
I used mobil 1 75-90 and had a whine @ the differential only when letting off the gas in gear. I found it to be the problem when I changed to regular(dino) 80-90 and noise was gone. I only have 9k on the clock of my 06.
