What brand gauges are the best for a turbo applic.
I'm going for the Defi Gauges as they are the only Jap gauges that read in US measurements and are 52mm-I think the 60mm are too big for the gauge pod. They have stand alone gauges D series, for about $169 a piece for EGT and oil temp, the two I am installing. I think the boost gauge is a waste of $$ on this application, as the boost is so low at normal driving conditions (with my S/C) IMO. If you want boost it is only $119. The defi link gauges are real neat, I just don't have room for the control unit with all my other junk!
I guess I am more interested in exhaust gas temp and oil press or oil temp to protect my expensive motor than I am worried if my S/C is leaking- I couldn't even guess where the heck it could leak from???? And I would guess the result of a "leak" would be loss of extra power. With only 2 gauges, I think I will stick to EGT and either oil press or temp. Too bad with the little area 3 gauges are too much! I think the boost gauge might be more useful with a turbo set-up, with the Vortech, the power delivery is so linear, max boost is up at the top of the rpm's. I also made 30 HP on the dyno between 8000-8900 Rpms!!!
The blacked out Defis do look great-so do the greddy!!!!
[B]I guess I am more interested in exhaust gas temp and oil press or oil temp to protect my expensive motor than I am worried if my S/C is leaking- I couldn't even guess where the heck it could leak from????
Since everyone's adding their two bits, here's what I've gone with and liked.
http://www.stage6motorsports.com
The picture on the homepage (at least, at the time of writing) is the daytime picture of the APEXi boost and EGT gauges (on my car actually, too ), I don't have a nighttime picture that came out well, but the color is a nice soothing (not too bright) bluish indiglo. It matches the blue of my head unit in that picture fairly well.
You'd have to ask Dwight at Stage 6 ( www.stage6motorsports.com ), he did all the work. Dwight has a knack for clean installs of stuff like that.
Originally posted by JoeD
But no matter what, stay away from Autometer. Autometer gauges are garbage.
I've been using Autometer for years on my Supercharged Integra and I can vouch for this. They are crap! They Always display inaccurate readings. I had the 6psi JRSC kit on my gsr and sometimes it would read 8 psi and sometimes it would read 9 psi. WTF? I didn
Yes crapometers suck. There EGT gauges utilize crappy probes and give about a 3 sec delay on temp readings.......thats big time lag that can blow a motor.
I personally like the greddy warning meter gauges since they match the dash lighting in amber/red and have instant replay and warning modes if you over step a parameter by prominently displaying an annoying red light.
The boost gauge and Egt should be the minimum with a turbo app however I would really urge any turbo user especially on stock internals to utilize a wideband 02 sensor. The greddy a/f is good but is not so hot in monitoring rich conditions for 11.5 and lower.
Greddy 60mm warning gauges. Light up same color as our interior. Full 3 years Greddy warranty from Greddy themself. I have been using Greddy gauges for years on all my cars. Never had any problems. They are one of the cheapest warning/memory gauges. The SOSs pod will fit the 60mm.
Check my avatar
Check my avatar
Ty.
Member S2000 Classifieds and For Sale
06-14-2007 05:03 AM
