What a about nitrous system kit???
Old 05-07-2002 | 10:40 AM
Live to Run's Avatar
Default What a about nitrous system kit???
I'm looking for big power at low cost... It's seem to have one solution!!! NITROUS??? But witch one??? So far, the ZEX NITROUS SYSTEM for Honda vtec is the best right now, 65hp(Max) of boost juice... I think ZEX have a computor command to control the juicy power perfecly??? It's easy to install and uninstall for the warranty...
If somebody try this thing... Let me know!!!
Old 05-07-2002 | 11:49 AM
GSRacer's Avatar
go with a direct port if you want it done right. i had a zex kit before and i liked it alot, but nitrous distribution is an issue.
ps: try clicking on the search button and don't forget to use the spell check
Old 05-07-2002 | 01:59 PM
cravnpup's Avatar
GSRacer is correct. The best kits are direct port. These do come at a premium because there is one jet per port, and it may require some custom fabrication. A second alternative is a "safe" dry kit. Maybe 70hp max for 4 cylinder cars. Whatever you do, get the system tuned on a Dyno with a wideband o2. Otherwise, you're just asking for trouble...
BTW, what kind of car are you driving? 108mph in the 1/4 seems a bit high for an NA S2000...
Old 05-08-2002 | 04:17 PM
I know it's the ZEX dry kit with computor control for Honda engine???
cravnpup... Try a S2000 before??? If, yes!!! Try again... Pup the gaz arround 8500rpm first gear and than launch the car??? You need rev's to do a good 1/4 mile!!! For everybody here... Mod's = Turbo or supercharged in that's all??? Come on... Intake, exaust, spark plug, tire and... Are mod's also in it's can make big change on the car power!!!
Old 05-09-2002 | 08:53 AM
cravnpup's Avatar
Yes, I have tried an S2K before. I also know Milo, Steve c, and Kwando from this board. I've raced about 8 S2K's (most modded, some stock), and not one has come closer than 1 car length in the 1/4 mile. When I was at sea level, my highest trap speed was ~ 99mph (of course I was pretty much stock back then). I'm sorry, but I have a very hard time believing that a bolt-on S2K will come anywhere close to 108mph in the 1/4... The fastest I've ever seen one run was 101, and that car was supposedly I/H/E + VAFC + DR's...
Post a time slip, and I'll gladly shut my mouth....
Old 05-09-2002 | 04:15 PM
kumar75150's Avatar
13.4 with bolt ons
I don't know.
Old 05-09-2002 | 06:48 PM
speed4tu's Avatar
Originally posted by kumar75150
13.4 with bolt ons
I don't know.
Very hard to believe But maybe if you pop the clutch at 8000 with no tire spin
Old 05-09-2002 | 07:18 PM
S2Krazy's Avatar
Maybe he's thinking in KM/H. That would be 67 mph.
Old 05-09-2002 | 09:04 PM
prm99v6's Avatar
I am running a zex setup and just put in the 75 jets today along with another bottle. I am running tomarrow night at the track, we will she what she does. With the 55 shot she ranmid 13's at 104mph with a gtech.
Old 05-10-2002 | 06:57 AM
cravnpup's Avatar
[QUOTE]Originally posted by S2Krazy
[B]Maybe he's thinking in KM/H.
Quick Reply: What a about nitrous system kit???
