Well I'll be..... We do have an adjustable steering wheel
Administrator
Helms Manual page 17-9
Nut E and Bolt F
The bolts are about 1" long which means you can lower your steering wheel up to 1" w/ some washers.
There you have it. I am not lowering mine as I am happy w/ the stock position but, just wanted to share w/ u guys.
Nut E and Bolt F
Administrator
theres not much too it.
remove the plastic on the bottom of the steering wheel (3 screws)
There are 2 nuts near the top of the steering column, 12mm on about 1" studs. The are about 6" apart and the highest mounting point. You shouldn't have a hard time finding them.
The other 2 bolts are on a U shaped braket on the shaft from the steering near the firewall. They are 12mm too.
Those are what you need to add washers on. I don't have a scanner, but its a really simple thing to do.
