welded diff
Old 09-30-2012, 05:44 AM
dwight's Avatar
Originally Posted by whitegv
Ah right. but our Diffs are the same?
Click on the link and read.
Old 09-30-2012, 06:13 AM
zeroptzero's Avatar
Received 3,740 Likes on 2,644 Posts
Isn't this something you only really do for drag racing purposes, not that beneficial for daily driving ?.
Old 09-30-2012, 06:36 AM
SgtB's Avatar
The thing about it is, if you need to weld the diff, you're welding the wrong diff. The pinion is made of candy cane on this car.
Old 09-30-2012, 06:52 AM
whitegv's Avatar
I have 2 diffs. will only be using this one a few times a year at most.
Is there any other Diffs that are direct fit that can be welded easier? i read something earlier about a kia diff?
Old 09-30-2012, 06:57 AM
SgtB's Avatar
Honest question here: What is your setup, and what do you need a solid diff for?
Old 09-30-2012, 07:35 AM
whitegv's Avatar
Basically stock engine wise bar dms manifold de cat and pipe and k&n fipk.
bc coilovers and camber adjustment.
having a play at drifting really. nothing serious else i would have.bought an s14.
Old 09-30-2012, 08:09 AM
SgtB's Avatar
The diff will probably die very quickly, welded or not. The stock diff can only take so many hard shock loads and the pinion shatters. Having it solid will make it die quicker.
Old 09-30-2012, 08:33 AM
eastcoastbumps's Avatar
The Kia 4.77 ring and pinion are interchangeable, but the differentials themselves are not interchangeable.
You will need a different differential for drifting. The stock diff is awful for it.
Old 09-30-2012, 08:34 AM
MM3Kwolik's Avatar
Old 09-30-2012, 08:56 AM
fernando.'s Avatar
I don't understand why you'd need to weld it in the first place? Maybe if you had a 240sx with a open diff or whatever, but I can get the car to rotate quite easily when I want to.
Quick Reply: welded diff
