weird thing that i found...
So I was doing my spring intake cleaning and i pulled all the tubes that go from the intake manifold to the valve cover and sprayed them with intake cleaner. I pulled the skinny tube that goes from the intake mani to the fuel regulator on the fuel rail and look inside and theres this tiny screw wedged inside. so i pull it out and it's a screw with threads that is has a flat head on it without a flat or star on the top. so it's almost like it's a push in type. weired thing about it is how did it get there. the way i look at is it was stopping the air going from the fuel regulator to the intake. i believe the airflow from the regulator to the intake is in that direction so the screw would have come from within the regulator. just for the hell of it check yours out. i removed it.
so now i don't have a S/C what harm do you think that it may have caused. i'm not talking about failure but now that i removed it will my gas mileage suffer? will it be better?
custom_bimmer
05-07-2007 07:48 PM
