Weird squeaking noise while accelerating.
Old 05-22-2009, 12:17 AM
prolux's Avatar
O and the ticking is caused because when matter gets hot it expands and when it cools it contracts, as you would know. When you turn your car off it starts to cool back to atmospheric temperature causing anything that was hot to slowly contract again. The ticking is everything moving shape. yeh absolutely nothing to worry about. Thats why you should warm up your car before giving it anything, because the "operating temperature" is basically the "operating size", cause its designed to run with all the sizing of the parts being that when they are hot. I believe metal expands at .02mm every 100 degrees C. So if you rev a cold engine your creating more wear cause its not the right size to be run high speeds!
Old 05-22-2009, 02:13 AM
badboy00z's Avatar
Thanks for the insight.
Old 05-22-2009, 09:26 AM
negcamber's Avatar
You can go to Radio Shack and get a "ground loop isolator" and plug it into the RCA lines going into the amp. That may work.
Old 05-22-2009, 12:45 PM
badboy00z's Avatar
Cool, I'll try that.
Old 05-23-2009, 01:49 AM
badboy00z's Avatar
So I got the Radio Shack ground loop isolator. Here's what it looks like:
The amp I have is the Boston Acoustics GT22.
So I went to install it and find that I couldn't because both ends of the isolator are "male" types. I'm not sure how to use the shorter cable as one end is just a single male plug. So I think I need to return it and get this instead. Any thoughts?
Old 05-23-2009, 02:39 AM
prolux's Avatar
Yes but if your gonna take this back, id suggest getting one from like a car audio place. That looks more for a home system. Even though they say for cars.
kolyan2k
03-24-2013 07:40 PM
ry4nolson
12-11-2012 02:53 PM
s2jerris
02-07-2012 08:13 PM
gtg749m
09-14-2011 12:44 PM
Robs14
04-24-2007 12:38 PM
Quick Reply: Weird squeaking noise while accelerating.
