Weird Scraping sound rear end
Hey guys,
I am usually good at determining where sounds are coming from but this one is tough. When I am driving my S sometimes I hear this scarping noise like the brakes are worn down but they are not. When I had it jacked up I looked for small rocks, listened for noises, nothing. When its on the ground and I am rolling in gear I hear the scarping noise, louder when I turn. If I put in the clutch it seems to go away. The only thing I have done in the past 5 months is swap the boots of the CV shafts because I had a vibration in the rear which went away.
Any advice would be great its annoying!
Do you notice if it gets louder when you turn left or right?
It could be a wheel Bearing (although in my experience sounds more like a helicopter sound) or check the wear indicator on the brakes to see if it is rubbing.
This only happens when I am driving at slow speeds and louder when I turn the wheel. It sounds like the metal rotor protector touching the rotor but it is not i checked.
a note: just because a wheel bearing doesn't have play, doesn't mean its bad. a good way to tell is have both rear wheels off the ground and the car in neutral and the ebrake off. and have someone spin the wheel and grab the spring. there should be no roughness(vibrations) felt.
but yeah do what downloader said, and check the backing plates rubbing the rotors. but also check the feelers on the pads. but another thing is sometimes there are hard spots in the pads that can cause a squeal even without breaking.
but its odd that it goes away after you press the clutch in.....hummm did you add enough grease in the CV joints? because if you didn't or the axles are bad. when you are in gear the axles have a load, and when you press the clutch in they are "unloaded" they still have a load on them just not as severe as with it in gear and coasting or accelerating.
ae86pwr
01-05-2007 07:32 AM
