Weird Idle
Weird Idle
Hey guys, first posting on the international forum and have a little issue with my car, hopefully you guys can help. I just installed a head on my car (old one had bent valves) and after everything was done, when I started up my car it idles from 1000RPM to 3000 RPM constantly. Any ideas on what the issue could be? It drives fine it's just the idle issue.
It's possible, however unlikely as you would most likely be leaking coolant too from the rear water passage. Tough to say for sure though. Is there a check engine light on?
Idle Air Control Valve. Seen it plenty of times. Start by cleaning it out with some brake cleaner. If that doesnt work purchase a new one. They are around $80 the last time i bought one.
I would just replace it. Its not hurting anything now so your safe to drive like that. Just annoying lol. The fact that cleaning it helped indicates thats where the issue lies. Maybe try to clean it a 2nd time and give it hell. Might fix it all together.
