weird engine noise
Old 09-12-2011, 01:42 AM
jubikej's Avatar
Default weird engine noise
My engine works weird right now. Please listen.
http://www.youtube.com/watch?v=rQMgMMePqh4
http://www.youtube.com/watch?v=n1nvVCxt-kQ
I checked valve clearance and they are ok, can it be a TCT?? What it will be if not TCT??
bye
Old 09-12-2011, 07:09 AM
Reckon's Avatar
Sounds like the infamous TCT...I'll see if I can find a link somewhere here where they have a vid of the usual sound.
EDIT: https://www.s2ki.com/s2000/topic/544...ain-tensioner/
Old 09-12-2011, 09:35 AM
Billman250's Avatar
Received 1,395 Likes on 836 Posts
Thats not TCT.
Sounds like a number 4 cylinder failure. look for high compression in cylinder 4.
Old 09-12-2011, 11:27 AM
jubikej's Avatar
Billman250@ what thing can do that?? Friend told me that it can be main/rod bearing problem :/
Old 09-12-2011, 01:57 PM
Billman250's Avatar
either way its bad.
was the car ever supercharged or turbo?
Could be oil jet bolt issue.
Old 09-12-2011, 02:05 PM
3en
3en's Avatar
Hey billman,
I have that same noise. I pulled the engine and the head and cylinder 4 is very lightly scored. It barely catches my fingernail. Is it something that can usually be honed out? Then I can put in new rings and a piston or should I start searching for a used engine? I can takes pics of it. I am going to be taking it to it a machine shop but I would like a your professional opinion if its even worth wasting a machine shops time.
Old 09-13-2011, 12:03 AM
jubikej's Avatar
I have no turbo or SC, stock engine. If it's true I'am cry ;{
If I push the clutch that noise is gone - I had brand new clutch kit already installed right now and it's not help.
Old 09-13-2011, 03:11 AM
Importedpower's Avatar
if you clutch in and it stops its a bearing in your trans... did you replace the bearings with that new clutch?
but idk how you would get such a bad sound off of the motor... whats your idle set at? i know mine was idling around 600 rpms when i got it and it sounded like sh*t with the ticking etc... got a valve adjust and bumped my idle up and it sounds fine... also a new tct... sometimes on startup i get a little ticking still tho
Old 09-13-2011, 03:19 AM
jubikej's Avatar
clutch release bearing was replaced with a new one
Old 09-13-2011, 05:53 AM
Billman250's Avatar
Originally Posted by 3en
Hey billman,
The stock cylinders can be bored. The machine shop needs to be familiar woth FRM boring and hone procedures.
Yes post a pic. sounds like your scoring is a non issue.
Quick Reply: weird engine noise
