Weird Electronic Issue
So this has been happening the last couple months or so..
Sometimes when the car is either slowing down or dropping down in revs, the radio will shut off and come back on. It will also sometimes flash the dashboard off and then on as well. The only dashboard light that will ever show up during this is occasionally the EPS light. Im pretty baffled as to what could be causing this.. A short somewhere? Possibly a corroded fuse or connection??
Anyone have a suggestion or guess as to what could be going on?
Since you dont seem to have any problem starting the car (for now), im thinking your batteries are good.
If you havent messed with the car's electrical connections, i'd say your grounds are still ok.
Your alternator is possibly going bad.
This is similar to a problem I was having, come to find out that my socket where you plug in the car charger and all the the other stuff, was loose. I got that fixed and the problem went away..
