Weak starting
Old 06-20-2013, 07:51 AM
oregoncurtis's Avatar
Originally Posted by jl56tc
Originally Posted by rrounds' timestamp='1371665313' post='22618461
Isn't 180 to 190 psi low compression for the S?
ROD
not us made engines.. its not good but its fair
A bit OT, but what would you do to an engine that is getting low compression across the board? Leak down test to see where the leakage is ocurring and go from there? Likely that the piston rings need replacement? Bore/hone the cylinders? Rebuild the head?
Old 06-21-2013, 08:32 AM
jl56tc's Avatar
Originally Posted by oregoncurtis
Originally Posted by jl56tc' timestamp='1371704542' post='22619662
[quote name='rrounds' timestamp='1371665313' post='22618461']
ROD
[/quote]
yeah usually the rings are leaking a little bit by... the best thing to do is get new rings hone the walls, wouldnt bore it unless you have to, change all the bearings since you have it apart new head gasket and goooooooooooooooooooo!!!!
Mr.Saturn
10-15-2013 01:37 PM
jon3501447
03-11-2010 02:14 PM
xtremesq
07-31-2008 09:48 AM
NoFriegue
03-26-2008 04:53 PM
atrain
04-30-2006 08:34 PM
Quick Reply: Weak starting
