Weak spark?
Weak spark?
How can i find out if i have weak spark? I'm building a pretty big project and can't get this car to start. So I'm trying to eliminate the possibilities.
Pulled the coil and held it near the engine block. It sparks.... looks a bit weak thoguh, however i don't really knwo what i'm looking for....
I did relocate the battery.... But I checked all my grounds.
IIRC u can tell if a spark is weak by the color of the arc.Boy had to search way back in my memory for dat one Correct me if I'm wrong but,orange/yellow=weak white/blue=strong.
Originally Posted by Fast Jack,Sep 23 2009, 02:15 AM
Also,the pro's are going to want more detail like: Engine swap and after-market mods.
gt35r turbokit
1000cc injectors
aem ems
gm map sensor
I get fuel/spark/compression/timing looks good.
spark looked a little weak so i am just trying everything....
If you could see the spark it should (key word is should) be enough to ignite the air fuel mixture. I dont think your problems spark I would look elsewhere. As far as telling if you have weak spark, Im not sure about just looking at the spark but you can tell with a engine oscilloscope. No a easy tool to come by. Or a spark plug tester.
i've tried 3 different sets of spark plugs.
Originally Posted by EK9MAX,Sep 23 2009, 04:40 PM
But if it's really weak. The fuel might be blowing it out or something couldn't it?
