Weak retainers?
Old 07-27-2004, 05:24 AM
Former Sponsor
Gernby's Avatar
Dark Sub Rosa, are you running FI? Everyone else, I think it is rather silly to say things like "you would be completely crazy not to replace them" or "without a doubt you should replace them" just because some other FI F20Cs have had retainers fail.
Old 07-27-2004, 06:17 AM
Big Ben's Avatar
You may have misuderstood me. If you are already doing engine work, then you would be crazy to not upgrade your valve springs and retainers. If you simply have a stock boost supercharger on a car that has less than 50k to 60k miles, theres really no need.
Old 07-27-2004, 06:23 AM
Former Sponsor
Gernby's Avatar
Apparently I did misunderstand, but Dark Sub Rosa didn't imply that he was "already doing engine work".
Old 07-27-2004, 06:28 AM
Former Sponsor
Gernby's Avatar
Originally Posted by Squeezer,Jul 27 2004, 08:20 AM
i'm curios too, whats the lifespan of the stock retainers and other components
Not to be an ass, but I would expect everything in the F20C to last at least 200K miles on a stock, well maintained and carefully driven S2000.
Old 07-27-2004, 06:40 AM
Dark_Sub_Rosa's Avatar
My engine is still N/A... my friend who was sayign this is FI.
I'm not planning on doing any engine work internally for a long long long long time. I can't afford to. Which is exactly why this retainer problem worries me. I can't afford to drop a valve. But putting in retainers isn't exactly cheap, sure the retainers are cheap themselves.. but I really don't feel like pulling my head or paying someone else to do it when there is no reason. I just adjusted my valves and none of my retainers were cracked.
Old 07-27-2004, 08:38 AM
Jason00S2000's Avatar
I would assume that too, but at 80k my valve guides were completely worn out.
Old 07-27-2004, 08:50 AM
this is interesting... I would expect everything to last at least 200k miles like Gernby said.
Old 07-27-2004, 09:05 AM
mxt_77's Avatar
So, before your failure, did you notice any peculiar noises or anything? Any signs that things were about to go badly?
Old 07-27-2004, 09:51 AM
apex2k's Avatar
Originally Posted by mxt_77,Jul 27 2004, 08:05 AM
While we're on the topic of retainers, are there any symptoms of retainers that are about to go? Any noises? Can they be inspected visually during a valve adjustment? Or do they just let loose?
Also curious.
Old 07-27-2004, 09:54 AM
Former Sponsor
Gernby's Avatar
Would you consider those 80K to fall into all of the following categories: 1) Well maintained, 2) Carefully driven, and 3) Stock?
Quick Reply: Weak retainers?
