Waterlock Hydrolock engine HELP
Here's what I've done so far.
Remove and replace spark plugs.
Got engine to turn over and got as much water out of the pistons and the throttle body and intake pipe.
Drained old oil and changed oil filter.
Poured Sea Foam into gas and oil to remove excess water.
Used Sea Foam into throttle body for recommended time.
Pulled PCV valve and blew it out.
Side note: I haven't tried to remove any water from the exhaust as I didn't think there was any in it. But when the car is revved up and the smoke comes out, there is light moisture on the tail pipes.
So... now the car is starting but it has a knocking sound and there is still a lot of white smoke. My check engine light is on. When the car is low idle the light is steady. When the engine is revved at 3k or greater it blinks.
About 30 min earlier the car would not idle itself at all. It would cut off if you let off the gas. Just before this video ended, the car idled itself at 2500, but then slowly dropped out and cut off.
I need some help on this big time.
Thanks for any info you can give.
Link to video:[media]http://www.youtube.com/watch?v=N0VlHFejFUM [/media]
1 Post
Originally Posted by fatjoe10,Jul 31 2010, 07:58 AM
That engine needs to come out of that car for inspection and replacement....
The video sounds like a jackhammer running. You really need to stop running it now before the damage gets worse.
Originally Posted by realblag,Jul 31 2010, 09:24 AM
X 2
pull the code its obviously for a misfire probably in all 4 cylinders plus the random misfire. You may not need to yank the whole motor out but I am sure the head needs to come off for inspection at the very least. Probably have a valve playing paddy cake with a piston.
AEM ftmfl. I think all you guys with hydrolocked engines need to get on AEMs case to stop pointing the filter upwards.
anyway, best case scenario: bent a valve so its idling funny.
