water pump life
On timing belt cars you typically have to remove the timing belt to get to the water pump. Since it's such a hassle to get the timing belt off anyway, you're better off replacing the water pump at the same time, which is around 100,000 miles.
But with the S2000, it'a a piece of cake to remove the water pump. And since they usually fail by gradually leaking or making noises, you are unlikely to get stranded if you just wait for some symptoms. But if you do wait, it would be a good idea to keep an eye on the coolant reservoir and the temp gauge.
Note - this is just an opinion. Many conservative people will disagree since there is a possibility of overheating if you aren't paying attention. There is no right or wrong answer. I currently have 135,000 miles and I'm still on my original pump.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
Originally Posted by Stratocaster,Jan 27 2010, 11:24 AM
You know, we don't have a timing belt. We have an accessory belt. We have a timing chain.
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
I just picked up my S2000 in the middle of December, 86K on the car. This past weekend I did the water pump at 88K, it might have gone a little longer but I was having to add coolant every other day and my accessory belt was sqealing from the coolant dripping on it..
